Urgent Urgent - WEFU / WEICHIA / Engine Speed Controller - Model No. 100 1904 116A
Kevin8686
10
Dear Engineers,
I urgently need the manual as well as the control signal line diagram for WEFU / WEICHIA / Engine Speed Controller - Model No. 100 1904 116A.
It's a part of Diesel Genset.
Kindly check the attached nameplate photos for the Genset as well as the speed controller.
The details of the speed controller are kindly as following:
- WEICHIA Model No. 100 1904 116A
- Serial No. E18120026
- Rated RPM: 1500 rpm
- Gear No. 128
The unit is currently down, your top urgent response is highly appreciated
 https://files.engineering.com/getfile.aspx?folder=88ff2674-26ed-47a2-af51-7c69e90b498e&file=WhatsApp_Image_2022-07-10_at_1.18.21_AM.jpeg
