UST LPG distance to high voltage pillars
Hi, couldn't find any references to minimal distance between under ground propane tank to pillar of high voltage. The pillar is grounded in case of a bridge of cables, and this creates a risk to close UST. Please advice, or give reference relevant. Is the electric distribution company has some rules about it? Regards E.L.
RE: UST LPG distance to high voltage pillars
How far away is the pylon?
A black swan to a turkey is a white swan to the butcher ... and to Boeing.
What "local regulations"? Where are you referring to as what one company says will have no impact on another.
If you do get a local grounding of a pylon from the cables then you can get a local increase in voltage. I don't know if this is enough to actually cause any issue in a buried tank or not and suspect its one of those things that just sounds like a good idea without any basis in fact or history of any issues
Einstein gave the same test to students every year. When asked why he would do something like that, "Because the answers had changed."
