Contact US
API 620 RT requirement for 70% JE
I know ASME Sec VIII Div 1 per UW-12 does not require RT for 70% JE on double welded butt joints.
Does API 620 per Table 5-2 require RT for 70% JE on double welded butt joints?
Thanks in advance for your assistance.
qcrobert
RE: API 620 RT requirement for 70% JE
Per Table 5-2, for "wetted" double butt joints only spot or full radiography is permitted, and thus only 85% and 100% joint efficiencies are used.
For roof double butt welded joints I believe the --, Spot, Full in the Radiography column are meant to be lined up with 70%, 85% and 100% in the efficiency column. Thus in a roof 70% joint efficiency is no radiography .
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
Low-Volume Rapid Injection Molding With 3D Printed Molds
Learn methods and guidelines for using stereolithography (SLA) 3D printed molds in the injection molding process to lower costs and lead time. Discover how this hybrid manufacturing process enables on-demand mold fabrication to quickly produce small batches of thermoplastic parts. Download Now
Design for Additive Manufacturing (DfAM)
Examine how the principles of DfAM upend many of the long-standing rules around manufacturability - allowing engineers and designers to place a part’s function at the center of their design considerations. Download Now
Taking Control of Engineering Documents
This ebook covers tips for creating and managing workflows, security best practices and protection of intellectual property, Cloud vs. on-premise software solutions, CAD file management, compliance, and more. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
