Flange Face and Valve Flange type
Hi Guys,
I would like to ask some of Flanges expert in here regarding whta type of flanges is this?
And this is the valve that use this kind of flanges,also i dont know what type of flange this valve have:-
Hope someone can help
RE: Flange Face and Valve Flange type
See figure 6 of ASME B 16.5 or what ever flange code this is.
Looks like it hasn't been used for a while....
i will be glad if someone can give me the name of this flange type and also some dimension for references. im looking for flange for stop valve J41H DN40 PN100
PN 100 isn't B16.5
DIN 2513 male and female. DIN 2692 are the gaskets.
The DN40 size would have a 75mm male boss, 76mm female socket.
https://www.weldflange.com/pdf/DIN2513-Flanges-mal...
Scroll down this one a bit https://www.marcelpiping.com/en-1092-1-flanges/
Basically the same as the DIN flanges. Don't think that extra hub on the spigot makes any issue.
