Engine performance test constant speed vs Variable speed governor
how can i test Constant speed governer engine in N mode of Eddy current dyno. Normally we are doing in N mode but if we go more than rated immediately hunting happened. Then which mode is suitable tell me. N mode / I mode / T mode
RE: Engine performance test constant speed vs Variable speed governor
Use T mode if you want to test the engine at various loads. Once the load exceeds the rated output, the speed will begin to drop.
je suis charlie
