Contact US
API 650 - Shell Manhole and Nozzel Inside Projection in a Vessel
Dear All,
I'm currently working on a project for a small API 650 tank (4 m3) and looking for nozzles and vessel design
I'm kind of confused about the criteria on when to consider inside projection of nozzle and shell manholes on vessel body (shell)
You can see here in this drawing that the shell manhole is projected at 72 mm
In this second image, there is no projection at all for another shell manhole.
For this Nozzel, there is a projection
Generally speaking, I found both ok, but not sure how to interpret API 650 regarding nozzle/manhole internal projection on a tank body.
Other information you may need:
  • Vertical Tank
  • This is a project with 05 similar tanks, technically the same, but they store different products (02 are flammables and the others are just corrosive)
  • Manhole is only 01 and located in the tank shell. About the nozzles, some are located on the roof and the others in the shell
  • Nozzel sizes go as minimum as 1" and maximum as 6". To be specific, 1", 2" (both SW Flanges), 3"; 4" and 6" (last three are WN Flanges) are the nozzel sizes
Can anyone share some feedback on this I'd really appreciate it
RE: API 650 - Shell Manhole and Nozzel Inside Projection in a Vessel
I believe the API-650 details show manways trimmed flush inside, and nozzles can be flush inside or extend inside as desired.
I'm not aware of any structural reason manways can't extend inside, just the longer the neck is, the more awkward it is to step through.
For roof nozzles, there is a requirement that nozzles used for venting be trimmed flush inside.
JStephen is correct - API 650 clearly shows manways made with reinforcing plates having necks trimmed flush and repad nozzles either flush or extending inwards from the shell. The same figure shows manway and nozzle necks with an inside projection when an insert is used. Longer manway necks are a little bit harder to get through but not that much in my opinion, especially for the 30" and 36" sizes. The neck projection inside is sometimes used for additional reinforcement of the hole in the tank shell. In a footnote, API 650 also says that you can use nozzle details in another figure for manways, so the internal projection is available if needed or wanted. Personally I would not reject a drawing or actual nozzle based on the presence or lack of an internal projection as long as proper weld details were used and there is adequate reinforcing.
I think they're always trimmed for personnel ergonomics, but it needs to be trimmed if you ever want to install a swiveling mixer on that manway.
Are you sure about the size of your tank - 4 m3?? that doesn't sound feasible to me.
If a mixer is a future option, you have to know now to make the flange and cover thicker. The internal projection may not limit a mixer swivel angle enough to matter.
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
Low-Volume Rapid Injection Molding With 3D Printed Molds
Learn methods and guidelines for using stereolithography (SLA) 3D printed molds in the injection molding process to lower costs and lead time. Discover how this hybrid manufacturing process enables on-demand mold fabrication to quickly produce small batches of thermoplastic parts. Download Now
Design for Additive Manufacturing (DfAM)
Examine how the principles of DfAM upend many of the long-standing rules around manufacturability - allowing engineers and designers to place a part’s function at the center of their design considerations. Download Now
Taking Control of Engineering Documents
This ebook covers tips for creating and managing workflows, security best practices and protection of intellectual property, Cloud vs. on-premise software solutions, CAD file management, compliance, and more. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
