Abbreviated Language in Professional Reports
Is it acceptable to abbreviate terms in an engineering report? We are working on an addition to a community recreation center. Most everybody calls it the rec center when speaking.
How should it be referenced in the report? Is it the rec center or is it the recreation center?
RE: Abbreviated Language in Professional Reports
- Andrew
TTFN (ta ta for now)
From my notes:
ABBREVIATIONS
THE DRAWING(S) CONTAIN COMMON ABBREVIATIONS. IT IS THE CONTRACTORS' RESPONSIBILITY TO CORRECTLY DETERMINE THE MEANING OF THE ABBREVIATION USED (CLARIFY WITH [OWNER | CONSULTANT | ENGINEER] AS REQ'D). WHERE MULTIPLE DEFINITIONS ARE GIVEN THE MEANING OF THE ABBREVIATION SHALL BE DETERMINED FROM THE CONTEXT OF THE USAGE[. THE FOLLOWING ARE COMMON ABBREVIATIONS THAT MAY BE USED IN THE DOCUMENTS]
...list of 100s...
This makes me glad I learned to type.
JHG
As time has passed, I see more of those items in the reports I read and review. In conversation, we all call it the rec center, the gym, the pool, etc. However, I was taught to keep the language/terminology professional throughout the document (acronyms are acceptable after first reference).
And don't get us all started on there vs their vs they're, accept vs except, then vs than, affect vs effect, and so on.
I got a monster tome last year that we'd commissioned to check how well a document we've been relying on for years had stood the test of time. Wherever it referred to the original report (on average, more than once per paragraph), this review took a line and a half to spell out in full both the names of the authors and the complete title - making the argument completely impossible to follow.
A.
Internal discussions have resulted in spelling out in cover letter and first reference in the report.
Thanks for all the discussion
In this case, they suggest:
When an abbreviation will be used in an article, first introduce it using the full expression:
an early local area network (LAN) developed by Digital Equipment Corporation (DEC) ... DEC's later LAN products were ...
https://en.wikipedia.org/wiki/Wikipedia:Manual_of_...
-- SirPhobos
Nothing should be in the cover letter (or executive summary) that is not included in the body of the report. Should also note that the PE stamp and signature are on the cover letter, which references the report. I typically do not stamp and sign the body of the report, that's on the cover letter.
I agree... I said it was a bad idea!
