Setting the path in windows 11
Hello
I have moved some VBA from a Windows 7 machine running Excel 2007 onto a Windows 11 running Excel 2022. The code selects five sheets, one at a time, does some basic formatting and then exports the sheet to a folder called Output as a pdf. On the Win 7 machine, I use CutePDF to print; on the Win 11 machine, I want to use the Microsoft print to PDF printer.
When I go to print the pages, the pages are printed correctly but are placed in "Documents", not "Output". Any clues why the Win 11 machine is not responding as the Win 7 machine please? Is it to do with the ChDir bit of the path? Regards.
CODE --> vba
Sub DoNagPrint() 'Stop 'Set the printer Application.Dialogs(xlDialogPrinterSetup).Show 'Set the printout path ChDir "D:\Office\New Age Glass\Excel\Output" 'Get Sheet data Dim projectReference, propertiesReference, propertiesReferenceE, notesReference, shutteringReference As String projectReference = Sheets("NAG").Range("A1").Value propertiesReference = Sheets("NAG").Range("I3").Value propertiesReferenceE = Sheets("NAG").Range("I3").Value + "E" notesReference = Left(projectReference, 8) & "-4" & Range("G4").Value & Range("C4") shutteringReference = Left(projectReference, 8) & "-5" & Range("G4").Value & Range("C4") 'Create file names Dim aFileName(5) As String Dim i As Integer aFileName(1) = projectReference & " - Calculations.pdf" aFileName(2) = propertiesReference & " - Properties.pdf" aFileName(3) = propertiesReferenceE & " - Properties.pdf" aFileName(4) = notesReference & " - Notes.pdf" aFileName(5) = shutteringReference & " - Shuttering.pdf" 'Write to files For i = 1 To 5 Sheets(i).Activate ActiveSheet.ExportAsFixedFormat Type:=xlTypePDF, fileName:= _ aFileName(i), Quality:=xlQualityStandard, _ IncludeDocProperties:=True, IgnorePrintAreas:=False, _ OpenAfterPublish:=False Next i Sheets("NAG").Activate MsgBox "Done" End Sub
RE: Setting the path in windows 11
https://www.mrexcel.com/board/threads/printing-vba...
dim myprinter as string
dim printer_name as sttring
printer_name ="name goes here"
myprinter = Application.ActivePrinter
Change_Form.PrintOut Preview:=False, ActivePrinter:=printer_name, PrintToFile:=True, PrToFileName:=PSFileName
Application.ActivePrinter = myprinter
If you include the full path in PSFileName that looks like it should work.
Doug Jenkins
Interactive Design Services
http://newtonexcelbach.wordpress.com/
I will try out and report back.
Build aFileName explicit and it should work as expected.
I was specific with the file name by adding the path to the filename and it works. But why did Excel 2007 - and Excel 2010 - work and not the new Excel?
Regards to you all.
