olympian GEH250 not able to start up
olympian GEH250 cracks but can’t startup ,only if fuel valve supplied directly.
With out diagnosis tool it is difficult to diagnostic the fault in ECM
Is there any way to spot which sensor by unplug the defect one or any other way
RE: olympian GEH250 not able to start up
I assume you mean it "cranks over" not cracked?
Also supply a lot more details and history of this machine. what does "only if fuel valve supplied directly." mean??
Like which control system, 1002T or Power Wizard, if Power Wizard which version.
If Power Wizard controls then there should be a fault code.
MikeL.
