Shvet,
I can't speak to specific books regarding scale-up, but I can speak from personal experience.
Overall, scale-up is a finicky business. Geometric scaling almost never is applicable due to the non-linear relationship between reactor volume (vessel radius) and mixer flow/shear, heating/cooling surface area, etc.
As such, simplistic ratios (10:1, 100:1) are not really helpful. Often scales will be determine by other factors - budget available, supporting utilities/equipment footprint required for pilot scale, etc.
It is not unusual for a scale-up process to require an entirely different reactor design once a certain size is passed due to the non-linear scalings. Two examples, perhaps:
1. Batch reactors often utilize a jacket vessel for small reactors, but have to add internal cooling mechanisms (jacketed baffles, coils, etc) when a certain reactor size is reached.
2. A certain fixed-bed reaction may begin to develop hot spots as vessel radius increases, which lowers natural turbulent mixing times and HX area/unit volume. This non-linear scaling may require a change in reactor design to something like a multi-tube reactor or even a complete design change to a fluidized bed reactor.
Overall, the key for a successful scale-up is to determine the key factors for the process - mixing time, mixing shear rate, cooling/heating load, necessity of uniform temperature distribution over fixed-bed reactors, etc. These key factors can't be found in a book; you have to be knowledgeable in the process and select appropriate scales based on practical and process considerations.
