Any API Standard that determines where to release the discharge of any Seal POT PSV
Vivaldi M. Smith
Chemical
Is there any Standard that I can use as a reference to where to release any discharge from the Pressure Safety Valves of the Seal Pot of a pump?
Not sure if you would find anything specifically for seal pots, but API-521 would be a good reference covering pressure relieving and depressuring systems.
*** Per ISO-4126, the generic term
'Safety Valve' is used regardless of application or design ***
*** 'Pressure-relief Valve' is the equivalent ASME/API term ***
