Dan Foss Soft-Starter Wiring problem.
The Starter has this nonsensical schematic showing two different wire schemes at N2 and N1.
Then the manual on the DF website shows this:
Which doesn't make much sense to me.
The unit did apparently come with a red jumper between N1 and N2.
Nothing tried seemed to work.
Does anyone KNOW how to hook this thing up?
The control voltage in our case is 120V L1,N
Keith Cress
RE: Dan Foss Soft-Starter Wiring problem.
By the way, you must have a jumper or thermistor between 5&6, or if you have an external OL relay, wire the OL contact there.
Thanks a ton Jeff!!
Keith Cress
By the way, been there, done that, which is why I knew…
This is on a rail-car down in San Luey. The guy working on it only gets down every week or two. Last weekend he/we were baffled to the point that he could never get it running at all and couldn't run the refrigeration A/C compressor because of it.
He'll head down again and I'll definitely let you know.
Keith Cress
