Depiction of Swagelok double block and bleed on P&IDs
lacajun
What is being used to depict Swagelok double block and bleed process interface valves on P&IDs? I looked at ANSI/ISA-5.1 and didn't see anything unless I missed it.
Here is the Swagelok catalog for process interface connections. Swagelok Process Interface Valves
Pamela K. Quillin, P.E.
Quillin Engineering, LLC
NSPE-CO, Central Chapter
Dinner program:
I'd just show the standard ball/needle/ball valve symbols but put them inside a location box. Saves space in the field, not on the drawings.
xnuke
"Live and act within the limit of your knowledge and keep expanding it to the limit of your life." Ayn Rand, Atlas Shrugged.
That's what I think, too, but others want something better. Thank you, xnuke!
Dinner program:
