Mixing Brands of High Pressure Fittings
Here.2.Learn
Materials
CA
Does anyone have experience in adapting an autoclave fitting over into a Butech T-Joint?
Need to configure The variable frequency drive of a waterjet using all butech fittings and lines but the best option for a gauge rental comes with an autoclave fitting. an adapter for the sizing seems to be available from both companies but their anti vibration fitting setups are slightly different. Any tips on connecting the two brands?
Should it even be done? we only need a good seal for about half an hour of use
butech lines and blocks are 3/8" 60 KSI CAT#60L6
autoclave fitting sizing is as per uploaded drawing
 https://files.engineering.com/getfile.aspx?folder=b9a1016c-c57b-4c63-b397-eb77538d4b69&file=Drawing_of_ADT100-HPM-M14F.pdf
