Please find the attached image:
As you note, I did need several equations to find the values (1.023, 1.004, 0.976, 0.955) due to the fact that the multiplication of two column vectors is a unique value.
How one can write a unique equation to get these numbers?
A work around came into mind that I use transpose of Lambda, then get diagonal of the result.
Your help would be highly appreciated.
