Lamina Ply Density Estimation
Hi, I would like to estimate the ply density of a wet layup.
I have fiber SGM, ply thickness, resin content. Is the formula below legit to use for calculating resin gram?
Once I have the resin gram, I will add them up with fiber gram and divide by the ply thickness from measurement to predict the ply density. Does it make sense to you? Thank you!
