Contact US
What is the heat loss?
The inner and outer surface temperatures of a glass window 5 mm thick are 15 and 5°C, respectively. What is the heat loss through a window that is 1 m by 3 m on a side? The thermal conductivity of glass is 1.4 W/mK.
Thank you so much! :)
RE: What is the heat loss?
IRstuff is right; it should be in your textbook. However, you could also do what we called following the units. Conductivity is in W per meter per degree Kelvin (= degree Celsius). Convert the thickness of the glass to meters, and set up the problem so the other units cancel, leaving you with only Watts.
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
Low-Volume Rapid Injection Molding With 3D Printed Molds
Learn methods and guidelines for using stereolithography (SLA) 3D printed molds in the injection molding process to lower costs and lead time. Discover how this hybrid manufacturing process enables on-demand mold fabrication to quickly produce small batches of thermoplastic parts. Download Now
Design for Additive Manufacturing (DfAM)
Examine how the principles of DfAM upend many of the long-standing rules around manufacturability - allowing engineers and designers to place a part’s function at the center of their design considerations. Download Now
Taking Control of Engineering Documents
This ebook covers tips for creating and managing workflows, security best practices and protection of intellectual property, Cloud vs. on-premise software solutions, CAD file management, compliance, and more. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
