Contact US
Fluid Flow
Fluid Flow
Fluid Flow
A Styrofoam cylinder, filled with water, sits on a table. You then poke a small hole through the side of the cylinder, 20 cm below the top of the water surface. What is the speed of the fluid emerging from the hole? Thank you.
RE: Fluid Flow
Czarinah, this isn't meant to be a guessing game. You are missing information and conditions to obtain that answer; the most important piece being the size of the hole.
- Andrew
RE: Fluid Flow
Salad, this sounds like a Fluids 1 problem, not sure I understand the issue with hole size? I doubt this question is intended to consider energy losses at the hole.
To simplify, I would convert potential energy at the hole, assuming the hole was recently put into the container and the water level has not yet dropped, and then convert to kinetic energy to solve for fluid velocity. This can be achieved using Bernouilli's equation, and is a classic question in basic fluid dynamic coursework.
RE: Fluid Flow
@ChorasDen Yes, thank you. I did solved it using the Bernouillis equation..and came up with a velocity of 2 m/s. Is that reasonable?
RE: Fluid Flow
Bernoulli euqation is the right way. Or you can use the simplified law of Toricelli, since the question only depends on the height of water surface to the hole.
Bernoulli -> Toricelli:
p1 + rho*g*h1 + 1/2*rho*v1^2 = p2 +rho*g*h2 + 1/2*rho*v2^2
p1 = p2 = patm
h1 = 0.2 m
h2 = 0 m
A1*v1 = A2*v2 -> A1 >> A2 -> v1 << v2 and v1 = 0 m/s
rho*g*h1 = 1/2*rho*v2^2
-> sqrt(2*g*h1) = v2 (Toricelli)
with h1 = 0.2 m
-> v2 = sqrt(2*9.81*0.2) = 1.98 m/s
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
Low-Volume Rapid Injection Molding With 3D Printed Molds
Learn methods and guidelines for using stereolithography (SLA) 3D printed molds in the injection molding process to lower costs and lead time. Discover how this hybrid manufacturing process enables on-demand mold fabrication to quickly produce small batches of thermoplastic parts. Download Now
Design for Additive Manufacturing (DfAM)
Examine how the principles of DfAM upend many of the long-standing rules around manufacturability - allowing engineers and designers to place a part’s function at the center of their design considerations. Download Now
Taking Control of Engineering Documents
This ebook covers tips for creating and managing workflows, security best practices and protection of intellectual property, Cloud vs. on-premise software solutions, CAD file management, compliance, and more. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
