Two stroke motor / thermal barrier coatings
What would be the effect of thermal barrier coating on the combustion chamber ( piston face and head ) on a 2 stroke ?
Some say it will cause detonation, i dont see why ?
Higher end of compression temp maybe but this would mean more pressure and also faster burn rate so that you could reduce advance and get same amounts of torque right ?
RE: Two stroke motor / thermal barrier coatings
So, why 2-stroke specifically and not SI combustion in general?
