Contact US
Convert Apple's LIDAR to AutoCAD
I received LiDAR data taken with an iPhone in ".ply" format. I would like to extract the data from it for preliminary grading information and convert it to AutoCAD format to incorporate in our drawings. I am not an Apple user, but I may be able to have my client save the LiDAR files in a different format.
What software do I need for this conversion? How do I go about doing the conversion in this software?
Is it possible to get contours from this data?
I have been able to open and view the file with MeshLab, but I have not figured out how to either extract the necessary elevation data I need or convert it to AutoCAD. Any help would be appreciated.
RE: Convert Apple's LIDAR to AutoCAD
If it's just a "point cloud" then processing with a bit of cunning and NOTEPAD may be all you need.
Open your PLY file with NOTEPAD and figure out if you have a long list of coordinates, or if it's a compressed mess of gibberish.
AutoCAD can run text scripts, meaning if you can type the command, you can create a text file script. There are tutorials for doing this.
WindWright, do you know if there is a way to convert the coordinates or the mesh into a 2D plan view with contours? I now have both a mesh and coordinates to work with.
That, I don't know in much detail. I've never tried to use AutoCAD that way. Back in the 90's I would make solids with AutoCAD but that was before I had better tools to do 3D stuff. Your problem sounds more like a GIS task. There seem to be a lot of surveyors in the world that still use ACAD so maybe they know.
Now that you can parse the file and use it to make a script in AutoCAD then presumably it's just a matter of selecting the right commands to include in the script. There are still a lot of such 3D commands in ACAD; hopefully someone else can show you an efficient way.
I wonder if SLICE has any application to a mesh, or if it's for solids only?
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
Low-Volume Rapid Injection Molding With 3D Printed Molds
Learn methods and guidelines for using stereolithography (SLA) 3D printed molds in the injection molding process to lower costs and lead time. Discover how this hybrid manufacturing process enables on-demand mold fabrication to quickly produce small batches of thermoplastic parts. Download Now
Design for Additive Manufacturing (DfAM)
Examine how the principles of DfAM upend many of the long-standing rules around manufacturability - allowing engineers and designers to place a part’s function at the center of their design considerations. Download Now
Taking Control of Engineering Documents
This ebook covers tips for creating and managing workflows, security best practices and protection of intellectual property, Cloud vs. on-premise software solutions, CAD file management, compliance, and more. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
