Longitudinal Y/T near ERW seam
Have some ERW pipe that contains a surface blemish close to the ERW seam. Its certified to CSA Z245.18. I'm not sure of the source of the defect but looks like bad scarfing, hardly noticeable if the light/sun is not just right. regardless had a transverse and longitudinal yield and tensile tests completed to validate strength of pipe is not impacted bye blemish so it can be used. Transverse results were good and the y/t was within spec. The longitudinal results exhibited good strength but the y/t was higher than spec. because the pipe was coated (removed for the tests) and the longitudinal test was so close to the ERW seam, if not on the ERW seam, does the y/t control at this point?
RE: Longitudinal Y/T near ERW seam
Hopefully nobody is making or buying ERW pipe any more.
"If you don't have time to do the job right the first time, when are you going to find time to repair it?"
