Heat exchanger book or software recommendations - operation away from nominal point
I wonder if someone could advise on a good book for heat exchanger design? I'm responsible for a system where that requires several heat exchangers. We know that these are liekly to be operating at several different but steady operating points. We're going to have to pick the best compromise nominal operating point but be able to calculate how the system will perform at the other operating points. We know which one of the operating points we require to be the most efficient but are still interesting in the other cases.
Can anyone recommend a good book on the subject? Or software?
Many thanks
Many thanks
RE: Heat exchanger book or software recommendations - operation away from nominal point
A less laborious way about this would be to use HX simulation software. Pro II - from Simsci can do this for you, and I suspect so can Aspentech Hysis. Else there are many specialist HX only simulation software - HTRI is one well known choice. All of these cost a bomb to lease short term.
To me you should hire a third party ,a contractor or an engineering company to perform the task for you . You will save time and you will get a report.
note :
Another good reference : Heat transfer in the process industry by Eduardo Cao .
My 2 cents
Pierre
For existing shell and tubes HX , you may want to perform some calculation . I've attached a resource from Checalc.com .
https://checalc.com/solved/heat_exchanger.html
Good luck
Pierre
