metboss
Petroleum
- Sep 12, 2012
- 153
Dear Experts,
We placed an order for Wellhead equipment (Material AISI 75 KSI, Design pressure/Working Pressure: 7,000 psi; Test Pressure: 10,000 psi, API 6A standard). As per API 6A standard "minimum hardness" for 75 KSI material is 197 BHN. But, during the raw material testing, hardness is found to be 180 BHN. As per my interpretation of API 6A, this is not acceptable. However, our vendor now justifies that material with 180 BHN still can be acceptable from design point of view and also it can still withstand test pressure of 10,000 psi. Please advise if I can accept the material though with less hardness. If yes, can I ask for any additional docs (such as design calculation or any other analysis)?
