how to convert GEM to MP4
shakila21
BG
hi
I have a series of movies in GEM format which can only play by GEM player. the problem is my system graphic is low and it can`t play these GEM files in 1080 resolution.so I need to extract these Mp4 files which are within GEM files and change it to 480p resolution. Is there any way or any decoder to covert it?
thanks in advance
thank you IRstuff for your reply. I have searched in google and nothing works... those website just convert movie below 200Mb.
Thanks anyway
thank you for your reply IRstuff. unfortunately I could not find the one which support GEM file till now...
agian thank you IRstuff for your recommendation. unfortunately this type of move(GEM file) which is run in gem player does not let recording. if try to record the screen it will be recorded all black.
thanks for your reply IRstuff. player shows the movie but i slow rate and laptop fan stars to go faster with load noise due to hot temperature.
I asked my question from some other people and they said one way to solve this problem is to find a decoder which could extract mp4 movie from gem file and now I`m looking for a decoder.
