Transfer switch question
budhiman
Is there a REVERSE transfer switch? I have seen a transfer switch that switches a load between two sources. Is there an application or product which operates opposite to a typical transfer - switch between loads instead of sources (A single source with the option to feed a small ampere load vs a high ampere load)?
