Pressure measuring in between two surfaces
There is a pressing machine and I need to measure the generated pressure between two pressing plates. As these plates are heated the instrument should be compatible with that also. Please suggest to me an industrial pressure measuring instrument to do this
Thank you
Thank you
RE: Pressure measuring in between two surfaces
They have a film that you may be able to use.
Actual pressure is a distribution across the surface and depends on what is between the plates, and it's uniformity in thickness and hardness.
At a previous job we used pressure sensitive film (Fujifilm) to measure contact pressure for knee prosthesis as that is a very significant contribution to polyethylene wear. I was not involved so that's literally the limit of my exposure (heh) to that application. However, if the 'instrument' needs to withstand elevated temperatures I do know if that is the right product for the application(if this website is any indication).
Walt
