Contact US
Temperature sensor for measuring flow consumption?
To measure the consumption of compressed air and water in normal liters per minute, is a temperature sensor also required?
How is it useful?
Thanks in advance.
RE: Temperature sensor for measuring flow consumption?
Normal units is a mass flow measurement unit that uses the European temperature standard, as opposed to 'standard' units, the US mass flow units with a different temperature standard.
If you want aninferred mass flow value which is a corrected value calculated from a volumetric measurement, then yes, you need the temperature and the wherewithal to make the correction, either in the instrument or a calc in the control system.
My opinion is that for water, there is so little difference between volumetric and mass that it is not practical to worry about the difference.
For gases, the primary flow elements for DP measurement technology can be sized for design conditions that are actual flow conditions, and the transmitter's output can be called mass flow, but that assumes that the design/actual conditions are stable and consistent at all times, which in most cases is not the case. The multivariable transmitter requires and uses all three measurements, DP, temperature, and absolute pressure to correct from a volumetric flow rate to a mass flow in Standard or Normal units.
Thermal dispersion sensing technology provides a mass flow output, by design, for either gases or liquids.
Coriolis meters measure the temperature and report it, I'm actually not sure whether temperature measurement is used for the mass flow calc or not (might be used for the reported density value) or whether the vibrating tubes alone provide the mass flow value.
Yes, not for water but compressed air as you need density correction. Coriolis mass flow meters don't need temperature compensation.
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
Low-Volume Rapid Injection Molding With 3D Printed Molds
Learn methods and guidelines for using stereolithography (SLA) 3D printed molds in the injection molding process to lower costs and lead time. Discover how this hybrid manufacturing process enables on-demand mold fabrication to quickly produce small batches of thermoplastic parts. Download Now
Design for Additive Manufacturing (DfAM)
Examine how the principles of DfAM upend many of the long-standing rules around manufacturability - allowing engineers and designers to place a part’s function at the center of their design considerations. Download Now
Taking Control of Engineering Documents
This ebook covers tips for creating and managing workflows, security best practices and protection of intellectual property, Cloud vs. on-premise software solutions, CAD file management, compliance, and more. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
