Priceof hydraulic cylinder
Momo-17
Industrial
BE
I would like to know the the estimated price of a hydraulic cylinder with the following characteristics : bore diameter: 32mm, rod diameter: 22 mm and a stroke of 2000 mm.
Thank you.
Hi Momo 17
Your best option is to get quotes from a supplier or manufacturer of hydraulic cylinders
That is a long stroke for that small of a rod. What pressure, weight does it need to act on? Double or single action?
Before going to a manufacturer for a quotation, determine your needs a bit better or at least understand your end requirements so the manufacturer can help you size it properly.
Ben Loosli
Yeah, there are different branded hydraulic cylinders with this size specification. Can you please specify the budget which you prefer to buy? I recently bought a Hydraulic Grapple Bucket Cylinder for my Bobcat excavator from the nearby store. It costs almost about $780.00 to weigh 30 lbs. You can also choose the adequate hydraulic cylinder for your business too
