How to extend concrete columns in Revit 2017?
criss21
Student
May 8, 2022
1
Can someone guide me on how to fix a concrete column height on Revit 2017?
As a beginner, I'm struggling a lot with how to fix this issue
Currently, I'm following this tutorial but couldn't find the solution
I don't have Revit on my PC so I can't share screenshots. But I am going to list some few steps
1. Select your column
2.Check the property tab
3.Look for the levels used for the start/end and modify column height from there. You can also use the offset function in the same property tab,
