Bobby223355
Automotive
What frequency precision for the inverse DFT do shaker tables normally use in order to convert an input PSD into an excitation time history?
My guess is that the frequency precision they use is far less than 1 Hz. Since there is an inverse relationship between the iDFT frequency precision (in Hz) and duration of created time history (in seconds), a frequency precision of 1 Hz means that the length of created time history is only 1 second, and so the shaker table software needs to repeat this calculation every 1 second which does not seem very efficient.
