Nicet Water Based Systems Layout Level IV
Just applied to take may test next month. Anybody out there with advice/pointers?
FOR ENGINEERING PROFESSIONALS Contact USThanks. We have received your request and will respond promptly. Come Join Us!Are you an
*Eng-Tips's functionality depends on members receiving e-mail. By joining you are opting in to receive e-mail. Posting Guidelines |
RE: Nicet Water Based Systems Layout Level IV
1. Review the suggested reference material published by NICET. I was familiar with the NFPA references but did thumb through the other books.
2. Take a first pass at the questions and answer all the easy ones that do not require a look up or is an easy lookup.
3. On the second pass, answer the questions that require some time or simple calculations.
4. On the third pass answer all the tough questions that take lots of time.
5. As a senior tech exam, you may have management questions and project management questions which should be no problem.
6. There isn't really any prep material to prepare you for the exam. I studied my old NFSA manuals and just forgot about obsolete things like large drop sprinklers.
7. The 4.5 hours goes by pretty quick so make sure you don't get bogged down on any single question. If you hit a trouble question, skip it for later and get the other points first.
8. I scheduled it for the weekend so no work crap could sabotage my taking the exam.
That was a pretty tough test, but it seemed to cover everything NICET said it would. Glad it is behind me now!
Travis Mack, SET, RME-G,
Ferguson Fire & Fab, dba MFP Design
www.mfpdesign.com
