Contact US
Generator Protection
What is the percentage of error limit for a ratio test to a CT class C800, 10000:5?
RE: Generator Protection
At 100A and 800V secondary the error will not exceed 10%.
I’ll see your silver lining and raise you two black clouds. - Protection Operations
Dear Mr. Melco001 (Electrical)(OP)28 Apr 22 21:07
[color #204A87]"... What is the percentage of error limit for a ratio test to a CT class C800, 10000:5?...."[/color].
1. General: a) Usually CT ratio are <10000/5 A. It is not impossible.
b) For C class CT, refer to IEEE C57.13 for detail.
c) For an equivalent IEC standard, see IEC 60044-1 (or later current edition).
2. As per IEEE C57.13, for a C800 class, 5A secondary CT
a) Limit of ratio error at rated current not exceeding 3% ; and,
b) Limit of ratio error at 20 times rated current not exceeding 10% ; and,
c) Will deliver a Secondary voltage of 800V to a standard burden of (4 ohm + 18.400 mH) at 20 times the rated current without exceeding the limits , see above a) and b).
3. An equivalent per IEC 60044-1 (or later current edition); a C800 class CT is equivalent to IEC 200VA 5P20.
Note: A 200VA 5P20 CT is considered very high burden, usually not required. But is possible.
Che Kuan Yau (Singapore)
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
Low-Volume Rapid Injection Molding With 3D Printed Molds
Learn methods and guidelines for using stereolithography (SLA) 3D printed molds in the injection molding process to lower costs and lead time. Discover how this hybrid manufacturing process enables on-demand mold fabrication to quickly produce small batches of thermoplastic parts. Download Now
Design for Additive Manufacturing (DfAM)
Examine how the principles of DfAM upend many of the long-standing rules around manufacturability - allowing engineers and designers to place a part’s function at the center of their design considerations. Download Now
Taking Control of Engineering Documents
This ebook covers tips for creating and managing workflows, security best practices and protection of intellectual property, Cloud vs. on-premise software solutions, CAD file management, compliance, and more. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
