High Temperature spring material
I'm looking for a spring material (preferably alloy steel) that could withstand operations in temperatures as high as 1200 deg F . Can anyone suggest a material please ?
RE: High Temperature spring material
*** Per ISO-4126, the generic term
'Safety Valve' is used regardless of application or design ***
*** 'Pressure-relief Valve' is the equivalent ASME/API term ***
Titanium is a good spring material. What is its maximum high strength temperature?
JHG
These will all be Ni alloys.
