There are 2 gas compression plant G
There are 2 gas compression plant GCP-A & GCP-B, each consisting of 3 nos. of reciprocating gas compressors. The rated discharge head of compressors at GCP-A is more than that of GCP-B. Discharge of both GCPs is connected to common outlet. What will be the final discharge pressure received at common header? How will the flow rate of each GCP matter?
RE: There are 2 gas compression plant G
CR
Flow rate will be whatever the flow rate of the compressors are.
Pressure will be irrelevant until it exceeds the max pressure of the B compressors.
Some actual numbers would help....
Best regards
--- Best regards, Morten Andersen
