Question about bolt forces due to base moment
Evaluating the bolt axial load due to a horizontal pin load causing a moment. I attached my napkin sketch. Is this a reasonable, conservative, approach to approximate?
RE: Question about bolt forces due to base moment
Cheers
Greg Locock
It is not reasonable and overkilling. If we assume the bracket is rigid enough, the faying surface will transfer the compression stress and a NA will develop around 11 in. from the right first bolt row. In this case, the tension developing at the first bolt row should be in the range of T= 576000/14= 41000 lbs.
Rather than think climate change and the corona virus as science, think of it as the wrath of God. Do you feel any better?
I would solve the issue by this method.- https://roymech.org/Useful_Tables/Screws/Bolted_Jo...
Scroll down to you see the sub heading “bolts withstanding bending forces”
