does a UPS room need a Clean agent protection as per NFPA?
Now there is an uninterrupted power supply room, which powery for ICT secondary euqipments, does this room need a clean agent fire suppression system ? or just a normal wet suppression system will be enough ?
RE: does a UPS room need a Clean agent protection as per NFPA?
Some do not like water.
SO how are you involved in this ??/ Installer, designer, ????? other
June 06, 2019 FM Global shares new fire protection and installation guidance for lithium-ion energy storage systems Publicly available research to inform building and fire codes for safe installation practices
