Macro: Batch Uncheck Weldment Document Options
Gupta65
IN
Attached is a macro to uncheck the following 2 Weldment Document Options from all the part files in the active assembly model. The macro will set the light weight components to resolved mode and will also skip any suppressed part components.
1. Automatically create cut lists
2. Automatically update cut lists
Macro libraries are set to SW2022 version. In case you're running a different version then update/correct the macro references as suggested in this video (don't worry on the fact that video is for fixing missing library error but check the process to update your macro library):
Deepak Gupta
SOLIDWORKS Champion and Expert
SW 2022 SP0.0, 2021 SP5.1 and 2020 SP5.0
Boxer's SOLIDWORKS Blog
