Silo Foundation
Silo Foundation
I was recently asked to design a silo foundation. I have never done this before. The silo is an elevated cylinder that is supported by a steel platform, similar to the image below. It seems to me that whoever designed the steel platform should provide signed/sealed drawings for the platform, as well as reactions for the foundation design (similar to the process for designing metal building foundations). Is that right?
RE: Silo Foundation
RE: Silo Foundation
RE: Silo Foundation
RE: Silo Foundation
Ah! You seem to be assuming a perfect world. "Signed/sealed" isn't a thing in all jurisdictions and it certainly isn't a thing if the item is being imported (which it possibly is).
Yes, you should be chasing down the reaction for the foundation design if they are available. But if they are not you can compute them yourself if you know the masses involved, the seismic conditions and the wind. (I have to do this a fair bit myself.)
RE: Silo Foundation
RE: Silo Foundation
RE: Silo Foundation
Interesting - never seen a drive through structure with a truss perpendicular to the traffic side. Usually see extended end plates, or knee braces.
RE: Silo Foundation
If they didn't provide signed/sealed structural drawings for the silo structure, would they even be able to install it in the state of Virginia? I bet this client isn't even going to get a permit. He said it is going on private property.
RE: Silo Foundation
You really don't need much else apart from the volume of storage and the material. Oh and I'd check the fixity of those columns. I presume they are pinned, but some designs use moment connections at the base.
RE: Silo Foundation
As for wanting to pour the footings tomorrow when they haven't even ordered the silo...well they're silly. The way I've handled that in the past is that I'll generate preliminary reactions and provide a preliminary drawing they can use for pricing - not for construction. If they choose to pour it without a final drawing it's at their own risk, and I explain that 1) the preliminary reactions will be based on assumptions that may or may not reflect the actual design of the silo (see diftLimiter's comment), 2) changes to the silo design between now and production could alter the foundation requirements, 3) anchor bolt layouts from these manufacturers are often not compatible with post installed anchors. I've had towers with anchor bolts that only work when cast in. The spacing was too tight to work with epoxy and violated minimum spacing. It was only after I detailed them to be cast in and developed with the foundation reinforcing that I got the anchorage to work.
RE: Silo Foundation
Something we have done with prelim drawings for foundations (for clients that seem to think "NOT FOR CONSTRUCTION" is only a suggestion) is to completely leave off the reinforcing call outs.
RE: Silo Foundation
Rather than think climate change and the corona virus as science, think of it as the wrath of God. Do you feel any better?
RE: Silo Foundation
Make sure that they do so at their own peril...
RE: Silo Foundation
RE: Silo Foundation
It's possible there are already two designers involved, one for silo and one for structural steel.
The design might have included partial fixity of the column bases, or might require seismic loading based on yield in the cross-bracing, etc., so not necessarily something to just jump into. They might or might not have included compression in those x-braces.
I think it's been pointed out elsewhere that a design approach may vary, but has to be consistent, so if you assume pinned bases and the silo guy assumed fixed bases, you may get some incompatibility.
A building permit is not always required, that may vary by jurisdiction. But it needs to be designed and built right regardless.
RE: Silo Foundation
that theybe sealed. They just have to be clearly identifiable.Rather than think climate change and the corona virus as science, think of it as the wrath of God. Do you feel any better?
RE: Silo Foundation
The company I worked for out of college specialized in "fast track" industrial projects. Which meant we were often putting foundations in the ground before final equipment / loading was known. If this was a "lump sum" contract, then the clients had to be willing to pay a big premium for this because the cost of re-work could be high. But, the key was that they'd get their industrial plant running 3 to 18 months earlier than if we waited for all the final information before building.
There are lots of tricks you do on the engineering side to make this work. You can use embed plates with nelson studs at the tops of your piers and then weld the steel base plates directly. You can make your piers a little oversized then used post-installed anchors.
My first project, we had already poured a large mat foundation when the operations people decided they needed a full stairway (rather than just ladders) to access the equipment. So, we doweled into the existing slab and poured an adjacent slab right next to it. A little inefficient as far as construction costs goes, but it saved a ton of time in the overall schedule.
RE: Silo Foundation
It happened to me two weeks ago, I was on the other side of this situation. The client and foundation engineers were gearing up to start forming up the foundation for a silo when they only had approximate loads that were tender/quotation documentation. I had to supply loads for a silo whose design was not finished yet. I have done enough with silos that I have a spreadsheet for all this.
Most/all of those unknowns can be readily surmounted IMO. Take the conservative choices. The only one I'd really try to get an answer for is the fixity of the bases. But that should be able to be determined by the base plate bolting pattern which should be much more easily obtainable. Even from inspection of that drawing (if it is accurate) I'd be comfortable calling it pinned. However you could always go ahead and design the foundation to take moment anyway. Like I said unless you have extremely poor soils you are going with ground beams or a raft slab so sorting out a stiff foundation isn't hard.
RE: Silo Foundation
RE: Silo Foundation
RE: Silo Foundation
We often find that the silo manufacturer does not have the expertise to design the structure, so either you get garbage loading from a mechanical designer using some off-brand program he doesn't understand or you have to wait for the sub-consultant the manufacturer hired to give you the loads. You are lucky to get anything meaningful in terms of wind or seismic loading. The equipment people say things like "sure we can design the structure - what seismic zone is this in?" I explain that seismic "zones" want away with the 1999 UBC and receive blank stares from the equipment guys.
I had an bin guy send me what he thought was a swell finite-element model of a bin support frame with a 20 kip column load. I explained to him that you can't just model one cell of a continuous frame multi-cell structure with shared columns and call it good. His column loads were at least 40 kips each but he simply didn't understand the concept of tributary area. Getting seismic calcs from him was absolutely out of the question.
In the end I told the Owner that his supplier didn't know what he was doing, did my own calcs for the column reactions, and designed the slab on grade accordingly.
