TomaszKruk
the customer has a pumping station with a force main and second pipe acting as gravitational bypass. Gravitational line works 24/7 - it allows them to discharge a fraction of the sewage without it going to pumping station further down the line so they use it.
I'm to redesign the pumping station and design a new force main in place of the gravitational bypass. Up to this point everything is pretty much ok, but they want me to recreate the ability to use the gravitational line as the bypass. So I'm to pump industrial sewage for a few kilometers, discharge some of the fluid into the old gravitational line I replaced up to this point, and then continue with the force main up to the next pumping station.
It creates a couple of problems - the system in complicated enough to leave us with no data (we cannot even establish what's the pressure loss in current system since it has at least one other inflow and the pipes vary in material and installation age). We know that currently the pressure just before the second pumping station is around 3 bar.
Could you suggest sufficient means for flow control, and much more importantly I think, pressure control? When it comes to flow they are currently doing that by a gate valve (ofc - what else). A butterfly valve with an actuator with remote control would not be a problem for my project, so (since I need flow measurement anyway) I was thinking installing that and a flow meter would solve the issue of max flow. What about the pressure though? I'm buffled because it's the first time I'd have to design a force line discharge on-line, not at the end of it. And with pressure 3 bar no less. I cannot say if it's a lot but I'd think I should dissipate the energy somehow since it's also around 200 m3/h. The medium is water with solutions that sediment over time and attach to all surfaces. The more robust the construction the better (I was suggested a pressure reducing valve, but I'm not sure if I'm thrilled about the idea of using it with such medium).
Any suggestions or discussion would be much welcomed and appreciated.
