DM2
- Oct 20, 2007
- 147
I have a copy/printer (Konica Bizhub C220) that I got during COVID to be able to work from the house. I needed something to print in color and scan 11 x 17 drawings.
The unit is plugged into a wall outlet. The wiring to the breaker will support 20 Amps, but the original breaker was a 15 Amp Breaker. The printer would print on the 15 Amp breaker but sometimes if the unit was asleep and turned back on, it would trip the breaker. I changed out the 15 Amp breaker for a 20 Amp breaker and it trips less often but. With COVID it's been hard to find a printer that will handle my needs or that doesn't have a 6 month delivery.
I'm trying to avoid pulling a larger wire and use a 30Amp breaker from my office to the breaker panel on the outside of my house.
Would a Start Capacitor solve the problem with the momentary loads?
Is there something else that would handle the momentary load?
DM
"Real world Knowledge isn't dropped from a parachute in the sky but rather acquired in tiny increments from a variety of sources including panic and curiosity."
DM
