PedroCarneiro22
Aerospace
I am trying to change the direction of z axis of shell 181 element coordinate system.
I am using the local and csys commands.
However, if i put the local coordinate system with the same orientation of cartesian the z direction of the elements appears in the wrong direction.
I tried a simple case of a square plate and tried to put the element coordinate system equal to original cartesian and it is not working.
Can anyone explain how to modify the z direction of the shell 181 coordinate system?
