Drag components in Creo moves the base part
Ard88
GB
thread554-380259
Hello!
I have exactly the same problem that was described in the referred thread!
Basically I have an assembly with some parts which are connected by joints (example "Pin")
The chassis have a "user made" constraint which is "default"
I checked also in mechanism, the chassis belongs to the ground.
So, why when I drag the rotation of a leverage the chassis is rotating, while a moving part is keeping parallel to the horizontal? This is very frustrating!
thanks for any help,
antonio
