BACN_mechanical
Hello everyone,
I am new to forums, I hope you can help me solve a question that I have had for a long time, which is not directly found in books or websites.
I have a variable primary chilled water system as you can see in the attached image, it's just a small sketch. Don't pay too much attention to details like valves, just focus on the chiller, pump and cooling coils. You can see that for each coil, its total cooling capacity and its design water flow were determined. The peak load of each coil occurs at different times. With this, if we add the peak loads of each coil, it would give 95 Tons, however, for reasons of diversity, which is 85% (here also ignore if this value is very high or low), the block capacity would be 80.75 Tons. Therefore, the capacity of the chiller would be 80.75 Ton considering the diversity of the system. I hope so far I have made myself understood.
With the block load of 80.75 Ton, it would determine the maximum flow that the pump would handle, which gives 193.8 gpm (considering a DT=10°F). Now, the question is: if I want to determine the head pump, how much water flow do I consider that passes through each coil? Is the diversity in the water flows of each coil considered to determine the head pump?
I have previously read some answers/solutions, which I list below:
1. Multiply the diversity factor by the design flows for each coil. For example, for COIL 1 its design flow is 48 gpm, this multiplied by 0.85 gives a flow of 40.8 gpm. For COIL 2 72gpm*0.85= 61.2 gpm and for COIL 3 108gpm*0.85=91.8 gpm. I don't consider this option very viable because the diversity factor of 0.85 is applied to the entire system (for the three coils), it cannot be applied to a given coil, because if the diversity factor of only two coils is analyzed in this case , would give another factor of diversity, affecting the flow of each coil.
2. Do not take into account the diversity factor and work with the design flows at peak conditions, and work with those flows to determine the head pump. This option, perhaps in a practical way, can be viable since this can be solved with a VFD. However, analytically during the mechanical design I don't see it feasible.
3. Work with the water flows required by each coil in block time. That is, the block load in this example is 80.75 Tons and occurs on Jan 15:00, for this time the water flow required by each coil would be determined. This means determining the water flow required by COIL 1 at Jan 15:00, the water flow of COIL 2 at Jan 15:00, and the water flow of COIL 3 at Jan 15:00. This information is not given by default by the software, but it is possible to obtain the water flows at various times with software such as HAP and CHVAC from Elite. This option seems to me the most reliable, since we are working with the block load and the water flow during the block load, and the water flow of each coil during the same block load. That is to say, everything is working for a certain moment, which is the one of maximum demand, and we are not mixing peak times.
I hope I have made myself understood, I thank you in advance for your valuable contributions.
