APDL Parametric model
I am trying to make a parametric model of a honeycomb sandwich structure. I have difficulty creating the geometry of the core and the plates using APDL. I want the panel to be completely parametric so changes in the geometry can happen without any problem. Can anyone assist me with that?
Part of my code is the one attached, but it doesn't work as intended.
PREVIOUS STEP IS TO CREATE THE PARAMETERS
!=====CREATING KEYPOINTS======
k,1,0,0,0
k,2,0,0,h
k,3,l*cos(theta),0,h+l*sin(theta)
k,4,l*cos(theta),0,3*h/2+l*sin(theta)
k,5,2*l*cos(theta),0,h
k,6,2*l*cos(theta),0,0
k,7,l*cos(theta),0,-l*sin(theta)
k,8,l*cos(theta),0,-l*sin(theta)-h/2
k,9,0,d,0
k,10,0,d,h
k,11,l*cos(theta),d,h+l*sin(theta)
k,12,l*cos(theta),d,3*h/2+l*sin(theta)
k,13,2*l*cos(theta),d,h
k,14,2*l*cos(theta),d,0
k,15,l*cos(theta),d,-l*sin(theta)
k,16,l*cos(theta),d,-l*sin(theta)-h/2
!===LINES GENERATION====
LSTR,1,2
LSTR,2,3
LSTR,3,4
LSTR,3,5
LSTR,5,6
LSTR,6,7
LSTR,7,8
LSTR,7,1
LSTR,9,10
LSTR,10,11
LSTR,11,12
LSTR,11,13
LSTR,13,14
LSTR,14,15
LSTR,15,16
LSTR,15,9
LSTR,9,1
LSTR,10,2
LSTR,11,3
LSTR,12,4
LSTR,13,5
LSTR,14,6
LSTR,15,7
LSTR,16,8
!====AREA OF THE CORE====
AL,5,22,21,13
AL,6,22,23,14
AL,23,8,17,16
AL,17,9,18,1
AL,18,10,19,2
AL,11,20,3,19
AL,19,4,21,12
AL,15,23,7,24
!===GENARATE THE GEOMETRY===
AGEN,n,1,8 ,0 ,0,0,-2*h-2*l*sin(theta),0
AGEN,2,1,8,0,-l*cos(theta),0,(-2*h-2*l*sin(theta))/2,0
AGEN,N1,25,32,0,0,0,-2*h-2*l*sin(theta),0
AGEN,N2,1,8,0,-2*l*cos(theta),0,0,0
AGEN,N2-1,25,32,0,-2*l*cos(theta),0,0,0
AGEN,N2,9,16,0,-2*l*cos(theta),0,0,0
AGEN,N2-1,33,40,0,-2*l*cos(theta),0,0,0
AGEN,N2,17,24,0,-2*l*cos(theta),0,0,0
AGEN,N2-1,41,48,0,-2*l*cos(theta),0,0,0
AATT,1,,1,0,1
!===CREATING ADDITIONAL KEYPOINTS FOR THE PLATES====
K,20001,2*l*cos(theta),0,(1.5*h+l*sin(theta))
K,20002,-N2*(2*l*cos(theta)),0,(1.5*h+l*sin(theta))
K,20003,2*l*cos(theta),0,-N1*2*(h+l*sin(theta))
K,20004,-N2*(2*l*cos(theta)),0,-N1*2*(h+l*sin(theta))
!====CREATING BOTTOM PLATE====
A,20001,20002,20004,20003
K,20005,2*l*cos(theta),d,(1.5*h+l*sin(theta))
K,20006,-N2*(2*l*cos(theta)),d,(1.5*h+l*sin(theta))
K,20007,2*l*cos(theta),d,-N1*2*(h+l*sin(theta))
K,20008,-N2*(2*l*cos(theta)),d,-N1*2*(h+l*sin(theta))
!=====CREATING TOP PLATE====
A,20005,20006,20008,20007
Antonis
k,1,0,0,0
k,2,0,0,h
k,9,0,d,0
k,10,0,d,h
LSTR,1,2
LSTR,2,3
LSTR,3,4
LSTR,3,5
LSTR,5,6
LSTR,6,7
LSTR,7,8
LSTR,7,1
LSTR,9,10
LSTR,10,11
LSTR,11,12
LSTR,11,13
LSTR,13,14
LSTR,14,15
LSTR,15,16
LSTR,15,9
LSTR,9,1
LSTR,10,2
LSTR,11,3
LSTR,12,4
LSTR,13,5
LSTR,14,6
LSTR,15,7
LSTR,16,8
AL,5,22,21,13
AL,6,22,23,14
AL,23,8,17,16
AL,17,9,18,1
AL,18,10,19,2
AL,11,20,3,19
AL,19,4,21,12
AL,15,23,7,24
AATT,1,,1,0,1
Antonis
RE: APDL Parametric model
You can refer Ansys's "Command Reference" guide for commands and "ANSYS Parametric Design Language Guide" for more information on parametric models.
I am familiar with this kind of process, my problem has to do with the generation of the honeycomb geometry. I can create a basic geometry but it doesn't always give the desired geometry. Below you can see part of my code for the generation. Do you think there is a way to code the generation of the core with specific parameters?
thanks again!
k,1,0,0,0
k,2,0,0,h
k,9,0,d,0
k,10,0,d,h
LSTR,1,2
LSTR,2,3
LSTR,3,4
LSTR,3,5
LSTR,5,6
LSTR,6,7
LSTR,7,8
LSTR,7,1
LSTR,9,10
LSTR,10,11
LSTR,11,12
LSTR,11,13
LSTR,13,14
LSTR,14,15
LSTR,15,16
LSTR,15,9
LSTR,9,1
LSTR,10,2
LSTR,11,3
LSTR,12,4
LSTR,13,5
LSTR,14,6
LSTR,15,7
LSTR,16,8
AL,5,22,21,13
AL,6,22,23,14
AL,23,8,17,16
AL,17,9,18,1
AL,18,10,19,2
AL,11,20,3,19
AL,19,4,21,12
AL,15,23,7,24
AATT,1,,1,0,1
Check whether there is requirement of only integers in commands.
In general, I want a script that when you run produces a core with a number of unit cells and the two faceplates, but I cannot find a way to accurately generate the geometry of my problem.
Also there is limitations of dimensions range that can be changed if you made the script with particular shape in mind (as in your case becoming specific to certain dimensions). Otherwise the remaining commands will not work and produce erratic results. For example- If I want rectangle to be horizontally longer, I need to give length>width. But if I give instead width>length, rectangle will be vertically longer and the command which will work correctly when length>width will produce erratic results.
Check whether that is case in your script.
