RMS of induction motor
Hey all!
Problem:
an induction motor is fed from a three-phase voltage source inverter connected to a DC voltage of 1500 V. Determine the RMS value (not the fundamental) of the motor voltage at 1.5 times base speed (base speed = 100 km/h)?
any ideas on how to approach this problem!
Problem:
RE: RMS of induction motor
Its usually better if you have a go at attempting the problem yourself first and post your effort, after which people will probably try and point you in the right direction.
