Reverse Sensors and bicycle racks.
This new car has all these gizmos that I have never had before.
Thinking about getting a Thule bike carrier for the tow hook with lighting board built in.
How do these things interact with reversing sensors and cameras? I presume the camera will be blocked but maybe not as its at the top.
Reverse sensors is it a rate of change or just a distance that they get triggered by and will learn that there is a bike rack on the back?
I am sure it will work as there is nothing about it on the internet. Just it triggered a wonder how it deals with that thoughts.
RE: Reverse Sensors and bicycle racks.
Also there is usually a way to disable the sensors from the car somehow. You will need to RTFM.
If you get ice on the bumper that often sets them off as well warning of a collision as soon as you go below 10 mph
Got to have a sit in one this morning and changed it into English menu so I could figure out what the options are. You can manually turn them off.
Never driven a car with all these gadgets before. I am wondering if most of them are just a PIA and more trouble than they are worth.
Keith Cress
When we were on the exercise areas we used to string 3 of them together.
Got my HGV license on one of them when I was 17, 3 normal forward gears and a crash 1st gear, low ratio box and 2/4 wheel drive diff box. No power assisted anything. After 2 weeks in Germany shifting arty positions every 6 hours all the drivers were built like the Terminator.
The lane keeping thing is the worst invention ever though - that one's thankfully permanently disabled, but some cars you need turn it off every time you start the engine.
Adaptive Cruise Control is the best - may not have got onto the Dacias yet though...
Electric auto handbrakes are also great unless you have another car without it or that doesn't auto engage it when you press the stop button. Then you can forget as you switch from one car to the next and the car starts rolling away as you get out....
Little things like heated wing mirrors and ones which dips down to show you where the kerb is when you engage reverse are nice, but you could do without.
If you're anything like me you will spend the first week reading the entire manual, setting it all up then completely forgetting how you did it 1 month later.
As for the radios / sat navs etc - they are complete extra set of things to forget how you set up.
Aye more than likely. You don't even get a manual these days. It comes on the car infostation thingy. And I suspect all I will get will be a quick start guide in 7 languages none of which is English.
Its got an electric handbrake with hill start assist. It has cruise control and limiter but zero clue if its Adaptive. I will be happy, with turn it on and it keeps a speed and kicks it out when I touch the brakes and press a button and it goes back to the previous speed.
Albert Einstein
I think the options will be Estonian, Latvian, Lithuanian, Polish, Russian, Czech, Hungarian and Slovakian. I can get two of them translated at home already. But I don't trust the translations to be full and complete technical translations without alteration. But rather to the way someone thinks it should work instead of how it actually works. That won't stop them trying at least 5-10 times getting it to work their way until they announce its broken its not working.
The Renault hill start thing is terrible though. It only comes on a a certain angle, but doesn't give you any notice or light to say it is working or active.
Then it only holds the brakes for about 3 seconds before releasing and the car hurtles backwards. Utterly useless. Use the little handbrake switch all the time.
The VW one is much better. Hold the brakes down when the car is stationary and a little green brake indicator comes on to tell you it's like you're holding the brake pedal down which then pings off as soon as you move. It seems to use the hydraulic system and not the little electric motor you hear whirring away when you use the electric handbrake.
Almost certainly not adaptive CC - you need a radar or lidar type thing. Too posh for Dacia.
If you get one of those bike racks, buy heavy duty lock cables to go thru both wheels and frame.
I'm a cyclist. I have friends that had bikes stolen off those racks.
ctopher, CSWP
SolidWorks '19
ctophers home
SolidWorks Legion
The other great thing is there are virtually no hills :D
been looking for an manual to download but even the French Renault manual portal doesn't have anything in any language.
There are shop configuration manuals that let you permanently set up many of the options.
My wife is 6" (20cm) shorter than me and doesn't listen to heavy metal.
But they are way way out of what I am willing to spend on a car.
It appears most of the car settings for Dacia is through an app. Or on the media screen if your model has one. And you plug your phone into the USB port on the dash to access them if you don't.
It runs windows SE :D <sarcasm on> which I am sure will make it stable and bug free <sarcasm off>
That can definitely be on my Christmas present list when the warranty runs out in 5 years time.
John R. Baker, P.E. (ret)
Irvine, CA
Siemens PLM:
UG/NX Museum:
Had a hire car delivered for an early morning trip to Heathrow a few years ago. I was well on my way down the M4 before I was awake enough to start taking an interest in what they'd given me and pressing buttons to see what they did. That game came to an abrupt stop when I landed on a memory seat button and the car started folding me quite efficiently into the footwell as I passed Membury Services at 80 mph.
A.
TTFN (ta ta for now)
Had a workmate that was over 195 cm and drove a Morris Mini (we call them doghouses here), only ones I saw him get in and out of it, still don't get how he managed to drive it though.
Albert Einstein
Thankfully I don't have to hire car places any more. When I worked for Eastern Airways I got caught for having 6 cars out with Enterprise in 3 days which blocked me from getting the 7th.
I seem to remember having a complete sense of humour crisis the first time I picked up a Megan. I wasn't the only one, I think 4 people ended up sleeping in them until the rental office opened up and someone showed them how to start it.
Walked around the car 5 times before one of the locals stopped laughing and showed me where the filler cap was....
Since I am the only driver I will have them just slightly different and toggle between them on long drives.
BTDT, on some random rental car, in the dark, where the gas cap release was inside the glove compartment,
