Welding symbols
Welding symbols
Good afternoon,
I want to know the welding symbols and annotations that must be put on a plane that has some bolts welded on it. I have seen it called resistance welding. I attach an image.
RE: Welding symbols
RE: Welding symbols
Rather than think climate change and the corona virus as science, think of it as the wrath of God. Do you feel any better?
RE: Welding symbols
RE: Welding symbols
RE: Welding symbols
RE: Welding symbols
RE: Welding symbols
RE: Welding symbols
RE: Welding symbols
RE: Welding symbols
Typically as part of weld qualification test studs are welded and are hammered 90 degrees and are expected to not fail in the weld.
RE: Welding symbols
Also, TYP has been suggested to not be used for repetitive callouts but rather a value with an X; ie 24X.
Ben Loosli
RE: Welding symbols
It is not the same as resistance spot welding.
It does not use the same symbol as resistance spot welds.
It is not the same as taking a bolt, or a stud, or a length of threaded rod and welding it to something with some other type of weld.
Depending on size the process is either:
Arc stud welding: https://www.youtube.com/watch?v=Ljz6twH-Pc4
or
Capacitive discharge stud welding: https://www.youtube.com/watch?v=GKR0v4UgjJ8
