Dear all please i need your help
Dear all
How to determine duration of the governing fire in order to size fire fighting tank and supply the water demand for the required duration
BEST REGARDS.
RE: Dear all please i need your help
If none then I would adopt the NFPA suite of codes.
And then employ a technical safety consultant who is familiar with fire risk and determination of fire fighting requirements.
Supply of water makes a HUGE difference. If you have none then it's normally one hour - just enough to allow everyone to get out before the plant burns to the ground.
Next to a river or the ocean is a different story.
It might only be one sentence to ask, but it could easily be six months work to give you a reply....
You need to talk to your fire brigade , they should be helping you . A call to your insurance broker is advisable .
You need to consider how far is your facility from the fire brigade and availability of water ( flow and pressure) .
I'm aware of projects in Asia where the water storage capacity is about 4 hours , let say 2000 m3 with fire fighting pumps pumps operating @ 500 m3/h .
Good luck
Pierre
