How to confirm if a shaft material is actually forged shaft?
Mech5656
127
I am buying a forged shaft material from a vendor to manufacture a pump shaft on lathe. My question is: how can I confirm if it is actually a forged material and not a bar? Is there a texture I can feel or anything visibly I can see to confirm if it is actually forged material? Is there a test to confirm that?
Material is:
415 SST material
5 inch OD x 100 inches long
Forging is done to produce a near net shape so the shaft wouldn't be a straight diameter along it's length. Bar stock that is a straight diameter can be provided as cast but is most likely wrought or extruded which are similar to forging. What is the importance of forging to you? If it matters, why don't you have a material spec from the manufacturer?
The only methods are destructive.
Is this a large, complicated, high horsepower shaft?
But beyond that, if they machined it from bar how do you think that they made the bar?
It would have been forged.
It may have been hot extruded, rolled (hot and/or cold), and/or forged (hot and/or cold), but the result is the same.
It was reduced from the original cast size.
And that is what matters. Along with chemistry and HT there isn't anything else.
I second what Ed said, how ever I will add the reason also to forge is to obtain grain flow as required by the end item manufacture(customer)
have them run a test sample with the grain flow direction.
ASTM A182/A182M-21
Standard Specification for Forged or Rolled Alloy and Stainless Steel Pipe Flanges, Forged Fittings, and Valves and Parts for High-Temperature Service
415 is 13-4 martensitic stainless steel, so I doubt it makes much difference, since heat treating defines the final properties while obliterating any grain flow effects. 13-4 never has a problem meeting minimum tensile properties, and it has the fairly unique characteristic of being fully hardenable to essentially unlimited thickness.
From a quality perspective I think you need to be more concerned about the ultimate source (i.e., geographic) of the steel, but the same applies to all metals.
"Everyone is entitled to their own opinions, but they are not entitled to their own facts."
Ironic metallurgist
Sorry brother grain flow does not change from heat treat. Only by means of mechanical forging. Worked with many forging parts for aircraft application.
We had to certify grain flow to our customers. Forgings have a higher tortional
strength rating. Used in shafts, gear shaft, gears in general. .
What if you order 2 of them and send one for testing? A lab can check grains under microscope and subject it to a tensile test or whatever other tests you need to certify. If you don't trust whatever material certs or certifications the material supplier is issuing with the material then that is the only way of checking.
We sent a valve for metallurgical analysis once because it failed in a very strange and creative way and the metallurgist was able to tell us exactly what the casting was made from and that the cast body was defective because the manufacturer didn't control the rate of cooling properly when they did the casting. They can be very helpful sometimes.
mfgenggear, In PH SS and other materials that get heat treated above recrystallisation temp you can't see the forging grain flow patterns.
Unless it is because of the intergranular trash that leaves indications.
I can re-heat treat a PH SS a number of times, making the grains equiaxed and reducing the grain size each time.
The toughness goes up a lot and the strength drops a very small amount.
The same thing happens with many alloys, depends on the hardening mechanism.
mfgenggear
Were any of those parts martensitic stainless steel?
It's a daily problem I have working in a large organization that civilian engineers project issues from one alloy onto all other alloys. For example they worry about the heat-affected zone properties in a 304 weld. The OP is looking for a reason to start a science project, when it would be less trouble to just buy the next more expensive alloy and sleep well at night.
Ed and Ironic
The steels are certified to AMS specifications in the USA, so it is held to a tight certification from the get go, and is expensive as hell.
the steel is mostly low alloy such as AISI 9310, 4340, 300 Mod., but the has been all types of steels. but not as common.
when forgings are required, for torsional strength , an actual part must be destructive tested, photos taken of the micro structure and grain flow.
how the parts are heat treated is very stringent and is a proprietary or AMS specification, and is usually flight articles. helicopters and fixed wing.
Materials in that category are being made against fixed processes.
I took the OP's question as being much more generic, especially since they didn't include any specification reference.
Hello All,
Thanks for your comments. They are all very helpful.
Can you name a supplier that can supply this forged material in above mentioned size (in the US)? I will get a quote on it.
Mech5656
If this is a commercial but must be nadcap approved. That narrows it down.get three suppliers to quote. pass on the cost to your customer.
The first two that I think of are Howco and Scot.
Hello TugboatEng & Edstainless:
Thank you so much for recommending the vendors for forged shaft materials. I have asked them for quote on this shaft material by looking them up on google and waiting for their response. Thanks again for the kind favor.
