BOM Balloon Shape
jzecha
Aerospace
Is it possible to define a different shape than a circle for BOM balloons?
My BOM balloons contain longer strings of text, so the Balloons get pretty big.
I would prefer them to either be Oblong Balloons or remove the balloon all together.
Are these related to a repeat region? If so, the symbol for the balloons is a property of the repeat region.
Yes they are, but I cant figure out how to change that Symbol.
I have 10+ options in Catia, but I can't see how to change it at all in Creo.
What I recall is that you add the symbol to the drawing and then use the symbol in the table setup; Creo cannot know about all symbols in the universe, so it limits the choice to those in the drawing (or at least in memory.) Catia may have 10+ options - Creo lets you create as many as you like. The difficulty is that Creo software developers often provide tools to do much more than the pre-packaged solutions that are convenient in other software. This usually means the user needs to read the user guide first.
See and
You might also need
Hi, 3DDave is right.
You have to create a custom symbol first and callout the rpt.index parameter in the symbol, enclosed in \text\. The back slashes are specific to symbol parameters. Then after placing a repeat region on drawing. Go to table properties, balloon symbol > custom, browse to symbol. Watch this might help: Link
